@retrodx,
@gopherdx The prioritization reasoning makes a lot of sense! Thank you for the thorough explanations behind each ranking. As for the DRM, is there any free resource out there to familiarize myself? I'm seeing a lot of paid courses available, but no document/pdf that I could just pick up and read.
In regards to the new scenarios
@gopherdx brought up -- I haven't gone through this type of material in class yet, so I'm going to make my best educated guess...
First Scenario
- Communicate with the pilots to get an idea of their current situation (in order of which flight would have the lowest amount of fuel onboard).
- Start looking for alternates in the area to prepare for an event in which the destination airport becomes unsuitable for landing safely
- After finding the alternates, send an amended release
- Continue to monitor situation and maintain communication with pilots if something comes up
Second Scenario
Assuming the plane is already fueled and is currently sitting at the gate with bags/pax onboard
- Talk to flight deck to let them know the flight will likely be delayed until we resolve weight issue
- Talk to ground ops to get a better understanding of the situation
- How long it takes for fuel trucks to arrive for potential de-fueling (assuming less fuel is possible on this flight)
- Potential to move cargo to a different flight that will still arrive close to original ETA
- Request for removal of passengers until flight is under MTOW
- Remove cargo that can be put on another flight and arrive close to original ETA
- De-fuel if possible and no other options are sufficient
Assuming the plane is NOT fueled and is currently sitting at the gate with no bags/pax/crew onboard
- Review fuel onboard. Will flight still be safe to get to destination based on WX and current conditions with less fuel? Did we originally plan to tanker "un-needed" fuel?
- If safe and legal, reduce planned fuel to meet MTOW limits.
- After flight crew arrives, let them know about the amended release (lower fuel from original plane due to weight)
- If fuel onboard cannot be adjusted, communicate to ground ops to let them know we will need to remove passengers from the flight.
- Get this process started early such that there is sufficient time to find volunteers and avoid forced removals.
- If no passengers are willing, remove cargo that can be moved to the next available flight close to original ETA
And for MLDW scenario, I think I'd follow the same steps as above, with the possibility of "dumping/burning" fuel near the ETA to hit the MLDW limits.
I'm hoping I'm somewhat on the right track with my thought process here! This was a really good practice session to think through scenario like this. Thank you for sharing these with me!
