popaviator
will an instrument approach always have either a PT or holding pattern?
Not to be mean but you are a CFII and don't know that? Did you ever do an arc in training?
Would you rather he didn't ask the question and never know? Just sayin'.Not to be mean but you are a CFII and don't know that? Did you ever do an arc in training?
You can have an arc on a procedure that still has a PT.
The first time I saw a straight-in only ILS was after I started flying 121.
Whoah, hold on. I don't think he ever said he'd never done an arc. The original post was just asking if ALL approaches have either a PT or a holding pattern. It's a legit question, depending where he flies, he might not have run across an approach that has neither of those.I know that, but an arc is a pretty big part of learning how to fly an approach. I couldn't imagine being thrown into one without having to practice or demonstrate the ability to do it.
You mean like this one?You can have an arc on a procedure that still has a PT. (I've seen one, but I can't remember where....)
http://naco.faa.gov/d-tpp/0904/00641IY12.PDF
Approaches are made with tight tollerances and if you began to get overwhelmed you can easily make some contract with the hills in the area.
I agree. Cessnaflyer jumped to the conclusion (perhaps prematurely) that popaviator has never flown an arc. It was a legit question with a simple answer. How he knows, and knowing is half the battle............Whoah, hold on. I don't think he ever said he'd never done an arc. The original post was just asking if ALL approaches have either a PT or a holding pattern. It's a legit question, depending where he flies, he might not have run across an approach that has neither of those.
Here's one with no PT and no hold-in-lieu...
http://204.108.4.16/d-tpp/0904/05537VDA.PDF
Trust me, I'm well aware. Don't bag on a guy though because he hasn't had the opportunity to see one.
If you don't know what you're missing, how do you know to ask?
:yeahthat:
As far as the question is concerned not every approach will have a PT. As far as a hold is concerned I would think most all would. ATC needs to send you somewhere if there are busy to keep you out of everyone's way in my opinion. I have never seen anything in a text anywhere to state all approaches will have a hold. I have never seen one that didn't but then again I have also never looked at every approach out there.
Interesting. Guessing that may be places where an approach would say Radar Required.
I've seen a few that just fly out towards a fix with no hold...usually big busy airports, as I recall
MEM used to have several of those, but the FAA has a goal of eliminating them.
