Dear All,
This might be a very silly simple question. But i was asked the same in a interview so posting a few from that interview.
1. How can one profile(depict) a induced drag in a wing??ways to reduce induced drag?
2. Vortex generators - difference between the ones used in mil a/c's and civilian a/c's
3. Can a disturbance travel upstream in a supersonic flow??if yes why if no why?
4. flow generators in the engine(g/t engines)
5. shocks - different between subsonic and supersonic shock? - why are the shocks in a supersonic flow detached from the surface?
and many more...
Thanks in advance mates.
Hey there Bravoalphakilo,
Tgrayson gave you some great answers there, but your questions are a little vague, so it's difficult to answer.
For question 1, I think the guy asking you may have been asking about the "drag profile" for induced drag, or essentially the relationship between induced drag and velocity. It isn't a linear relationship, but as velocity increases induced drag decreases. The curve "opens" upward, to help you picture it. The second part of the question has a really easy answer then: you can decrease induced drag by speeding up.
I think Tgray's answers to #2 and #3 pretty much say everything there is to say on the subject. Vortex generators change the airflow from laminar (smooth) to turbulent. Generally turbulent flows are bad from a drag perspective... but they also separate later than laminar flows. Since separation is also bad from a drag perspective, it is kind of a case of the lesser of two evils. But as far as I know, no difference between military and civilian versions.
I have never heard of a "flow generator" in a gas turbine engine, either.
Like Tgray, I have a terminology problem on your question about "subsonic" versus "supersonic" shock waves. In my understanding (which is not perfect-- it's been 12 years since I really studied this stuff) when shock waves form the flow is at least locally Mach 1 or above, even though the aircraft may be below Mach 1. A good example of this is the flow over a wing when the aircraft is in the transonic regime. The aircraft could be below Mach 1, say .9 Mach for example, but because the airflow speeds up as it travels around the wing it may hit Mach 1 (or greater) at some point along the wing. As the top surface of the wing begins to bend away from the direction of the flow a shock wave will form. The laymen's explanation that I have always heard for why this occurs is because the supersonic flow cannot follow the curve of the wing and begins to separate and expand. This is the only context that I can place for the term "sub-sonic" shock wave.
For your last question, Tgray talked about shock waves being attached or detached. Basically, shock waves are "attached" when the body has a pointed leading edge-- imagine a sharpened pencil moving through the air at high speed (above mach 1) for example. When the leading edge is blunt, like the nose of the space shuttle, the shock wave is "detached."
Detached shock waves are curved and depend on the shape of the body forming the wave. Still, for some small portion of the shock wave the angle between the wave and the direction of the flow is 90 degrees. At this point, the flow following the shock wave becomes subsonic.
Attached shock waves (aka oblique shock waves) form at an angle to the flow that is greater than 0 (parallel the flow direction) but less than 90. Across those types of shocks, the flow still slows down, but not to below Mach 1. The equations that describe the pressure, density, and temperature changes across the two different types of shock waves are a little different as well.
One last point on shock waves... Tgray already brought this up, but his explanation may have been a little technical. Imagine that pencil example from before. The tip is pointed, so of course an attached shock wave forms at high Mach. Now imagine that you zoom in on the point of the pencil. No matter how sharp the pencil is, if you zoom in far enough it will look blunt. So really the "attached" shock wave in this case, is not really attached. There is still that "normal" region, even with a very sharply pointed object. It is just very small. So when dealing with real objects, scientists ignore the very small region where the shock wave behaves "normal" in many calculations. That is what Tgray meant about the radius becoming zero. No objects are PERFECTLY pointed all the way down to the atomic scale, but it is a close enough approximation to treat them that way for many applications.
