ILS Perfomance Classification Codes
F9DXER
While doing OJT with a new hire, we came across this NOTAM for KLCH
!LCH 04/084 (KLCH A0263/16) LCH NAV ILS RWY 15 FACILITY PERFORMANCE CLASSIFICATION CODE CHANGED TO 1B 1604292229-PERM
I had never heard of a Classification Code for an ILS setup. So I had to look into further and with the help of our training department this is what was discovered and passed on to me
As we become more performance based equipped, the FAA has realized a need to classify those performances. Hope this explanation is sufficient. FAA Order 6750.24E
One can also look in the "Manual of All-Weather Operations", 3rd edition 2013, ICAO Doc 9365
The following is taken from the ICAO Document, it has tables and graphs that I couldn't paste here.
If anyone wants a copy I have it as a PDF document
The ILS facility classification system provides a more comprehensive method of describing ILS performance than the
simple CAT I/II/III classification. An example of an ILS facility classification is “III/E/4”. ILS facility classification is
described in Annex 10, Volume 1. A facility’s “class” of performance is defined by using three characters as follows:
a) The first group of characters (I or II or III) indicates conformance to the facility performance category
standards contained in Annex 10, Volume I. This character indicates if the ground equipment meets a
facility performance Category I, II or III.
b) The second group of a single character defines the ILS point (Figure C-1) to which the localizer
conforms to the facility performance Category II/III course structure tolerances. These classifications
indicate ILS conformance to a physical location on the approach or runway as follows:
1) A: 7.5 km (4 NM) before the threshold;
2) B: 1 050 m (3 500 ft) before the threshold (CAT I decision point);
3) C: Glide path altitude of 100 ft HATh (CAT II decision point);
4) T: Threshold;
5) D: 900 m (3 000 ft) beyond the threshold (facility performance category III requirement only);
6) E: 600 m (2 000 ft) before the runway end (facility performance category III requirement only).
c) The third group of a single character indicates the level of integrity and continuity of service. It is
generally accepted, irrespective of the operational objective, that the average rate of a fatal accident
during landing due to failures or shortcomings in the whole system, comprising the ground equipment,
the aircraft and the pilot, should not exceed 1 × 10–7. This criterion is frequently referred to as the
global risk factor. In Category III operations, this objective should be inherent in the whole system. In
this context it is of the utmost importance to endeavour to achieve the highest level of integrity and
continuity of service of the ground equipment. Integrity is needed to ensure that an aircraft on
approach will have a low probability of receiving false guidance; continuity of service is needed to
ensure that an aircraft in the final stages of approach will have a low probability of being deprived of a
guidance signal. Integrity and continuity of service requirements are defined in
Annex 10, Volume I,
Chapter 3, 3.1.3.12, for the localizer and Chapter 3, 3.1.5.8, for the glide path.
There's a section in the A/FD (now called the Chart Supplement apparently) that covers this as well. It looks like the same info.
Damn ICAO. Used to be an ILS was an ILS, maybe some of the big boys had cat 2 or occasionally cat 3, now we got 20 character codes for equipment in flight plans, age 65, and don't even get me started on "line up and wait"...
I've seen these before, and had a captain ask what it meant. Since our training/standards guys work banker hours and we operate mostly at night, I found the same basic info on the FAA website. (Note: the controller at said location had no idea what it meant).
Seems like extraneous information. If you downgrading the ILS from what is on the plate, tell me that (i.e. CAT 2/3 NA, or DH now 250'). If you're upgrading the ILS, well then we'll have to wait for a new plate anyway so that's more useless information to me. I really hope that the agencies don't start doing these "ILS Downgraded from 3D to 1B" kind of notams and that's it.... Or else I'll be filing a bunch of ASAPs. Seems like the FAA and ICAO are just inventing new things so some body can justify their phony bologna jobs. Can I get a "harrumph!"
Of course if I just continue to not read NOTAMs at all, it's not a problem.
