FAA Order 7110.65 - Air Traffic Control - Paragraph 3-84
http://www.faa.gov/avr/afs/hbat/hbat9412.txt
A. Air Traffic Operations.
(1) Flight Procedures. The current edition of FAA Order
7110.65, "Air Traffic Control," paragraph 3-84, specifies air
traffic procedures for ILS critical area protection. In general,
the runway's appropriate CAT I, II, or III critical area is
restricted for all aircraft and vehicle operation whenever any of
the following conditions exist:
1) the reported ceiling is less than 800 feet
2) the visibility is less than 2 miles
3) an aircraft on the ILS approach is inside the outer
marker (OM) or fix used in lieu of the OM, except a preceding
aircraft approaching the same runway or another runway may pass
over or through the area while landing, taking off, or exiting
the runway.
(2) Ground Procedures. In addition, vehicles or aircraft
operations are not authorized in or over the area when an
arriving aircraft is inside the middle marker when conditions are
less than 200 feet and/or RVR 2000. The entire longitudinal axis
of the preceding aircraft must be clear of the CAT III critical
area (approximately 250 feet either side of centerline) before
the aircraft on the ILS approach, or an autoland approach,
reaches the middle marker (MM) or 200 feet above ground level
(AGL).
B. Limitations. While it may appear to be desirable to
completely restrict critical areas from all surface traffic, this
is not generally feasible since normal access to and from the
runway, terminal areas, and ramp may necessitate movement through
these areas. In general, the localizer critical area for CAT
II/III airports/runways extends along the runway approximately
250 feet on either side of centerline. CAT II/III critical area
dimensions are based on the assumption that the entire
longitudinal axis of the aircraft/vehicle is clear of this area.
Aside from necessary ancillary components, ILS critical areas
would need to be established in order to conduct operations in
CAT II/III weather conditions at an ILS airport/runway currently
limited to CAT I operations.
