GreenDayPilot said:
... but as a pilot, we must know every damn detail about everything. I'm pretty sure when you get type rated in an jet you dont just learn where everything is, instead, you learn every small detail about it... hydraulics, electrical, pneumatic systems, etc..... I doubt all those type rated pilots are mechanics, but they are indeed pilots.... meaning, they have to know the specifics...
What is the diameter of the spark plug wires on the plane you flew last?
What was the gap on the speak plugs?
What is the specific gravity of the Avgas you used?
How many cords were in the nosewheel tire?
You'd be surprised how little systems knowledge is required for many type ratings. Pilots fly airplanes - - they don't engineer or build them. If I can't see it, if I can't touch it, if I can't affect it when it's broken, there's not much reason for me to know about it. I have found that the more complex the airplane, the lower the level of detailed knowledge is required. This idea that one should learn every detail because the examiner might ask is pure nonsense. Learning it because a student might ask is nonsensical, as well. Learning it because it interests you is fine.
If an examiner might ask, I'd say, "I don't know. I don't inspect it before or after flight, and I know of no procedure that requires I touch it - - I just know that when I actuate this switch, it causes the flaps to go up or down, and that it's controlled by this type of electricity from this source and it's protected by this circuit breaker, etc., etc., etc."
If a student might ask, I'd say, "I don't know. It's not important to know WHERE it is, it's important to know how it works, and what to do it if stops working. If you're really set on knowing where it is, we'll take some time later to go ask a mechanic. HE'S the one that needs to know WHERE it is."
