tlewis95
I drive planes
It happened yesterday afternoon.
Not really a big deal, and I don't know if I would even call it a failure or a "quit."
But I was landing a rented Cessna 140 at homebase, and at about 200 feet high on final there was a slight roughness in the engine. After that, it sounded the same as it did before, mainly because I was doing my usual mostly power-off approach.
A few seconds after my perfect 3-point touchdown, the windmilling stopped.![Confused :confused: :confused:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f615.png)
So I roll it to a stop on the runway, and have to play with it a bit to get it started, then taxi it back to the ramp.
I am not really sure what could have caused it. It is the coldest (8F) that I have flown that plane, and have since talked to another CFI that has had this happen to him twice in the summer, with this same plane. (but on base)
The carb heat was on, and performed just fine in the run-up, and it was idling just fine with the carb heat on and off before the flight.
