HSI Question
jwp_145
GhostRider in the Sky
Hey guys,
I've looked through the 600 page G1000 Instructor Reference book from Garmin and cannot find this answer.
On the HSI's lateral deviation scale, rather than the standard circle and four dots, there are simply two dots on each side of the scale. I've also seen other HSIs like this too.
The Instrument Flying Handbook says that most lateral deviation scales are twelve degrees each side when fully deflected. So, am I correct to assume that each one of those dots is 4 degrees of deflection? The CDI on the second dot would be 8 degrees deflection, then full scale would be 12?
fish314
Hey guys,
I don't know anything about the G1000, but my aircraft has an EHSI with two dots either side and each dot is 5 degrees, so that makes the second dot 10 degrees. I don't know about full scale deflection... I just say "more than 10 degrees".
Scandinavian13
I looked in the manual and it has 4 dots. It also references that it can be changed automatically, or manually, depending on your settings. Automatic revises the scale depending on the Flight Phase.
H46Bubba
Hey guys,
Do you have the newest edition of the Instrument Flying handbook? If not the new addition has a buch of G1000 stuff in it.
R
Roger, Roger
Guest
Peg to peg with a VOR or LOC is the same as on a standard CDI, IIRC. With GPS it varies depending on which mode (enroute, terminal, lnav, lpv) it is in.
jwp_145
You are referring to the GPS nav source lateral deviation scale according to the ENROUTE, TERMINAL, or APPROACH Mode phases of flight. I know exactly which page you are referring to because I stared at it a lot yesterday.
And whoever asked about the new Instrument Flying Handbook, while it does use the G1000 for pictures, it doesn't have any information on that particular avionics suite. It simply uses the G1000 for the illustrations.
And I believe the person that said five degrees per dot had about the best suggestion. Thank you guys.
