Okay, so:
MAP - [(HAT)/(Descent Angle)]/100 = VDP.
Let me try a sample.
Say the MDA for the approach is 800 HAT and you want a 2.5 degree descent angle. The MAP for the approach is 6 DME.
6 - (800/2.5)/100 = VDP
6- 320/100 = VDP
6-3.2 = VDP
VDP = 2.8
So your VDP is 2.8 DME.
Sound right?
Correct. And you can cross-check this also by the logic test (ie, does it make sense?) In your example, assuming the navaid (VOR) is the FAF and the DME is increasing as you get to the MAP, for a 3 degree glidepath, you'd subtract 2.6 miles from the 6 DME for a VDP of 3.4 DME. That makes sense since with the shallower 2.5 degree GP you're wanting, you have to descend earlier (sooner....that is, at 2.8 DME), than with the 3 degree GP (3.4 DME). So it passes the logic test. /ubbthreads/images/graemlins/smile.gif
The biggest thing you have to remember is "how do I apply the answer I come up with?" Do you add it? Subtract it? You really need to cross-check the beginning of the runway and go from there. For example, your 6 DME MAP you mention may start 1.0 miles from the beginning of the runway. In that case, you'd have to take that extra 1 mile into account, and your VDP would actually be located at 3.8 DME, or 3.2 miles from the beginning of the runway. Make sense? To get this info accurately, look at the profile view of the instrument approach, and see where it is that you're computing from........"walk" back from the beginning of the runway with your figure that you come up with, then match it to the correct DME point for you to use as your cockpit reference.
