NamarkAviation
Active Member
Folks,
after extensive annual this bird needs flying. The flying I do is not sufficient to keep things lubricated. So I am hoping to attract some qualified pilots who need that multi time.
If you are interested, you can be added to Named Pilot on policy lovering your time required substantially.
You must have a minimum of Private MEL/Instrument. You will require 1-2 hours check out to make sure you are familiar with the systems: If required by insurance, I will fly with you for additional 8 hours at no charge (travel expense only) (10 hour check out) POH will be provided in PDF prior to check out.
Flying this fully IFR equipped WAAS Avidyne and Garmin (Avidyne not shown on photo its IDF540 touch screen FMS) , Sandell 3308, Flight director and fully coupled autopilot.
A nominal $200-250/hr DRY (depending on insurance cost of adding you). This is your opportunity to fly a REAL plane without the cost of ownership (investment). Photos attached.
Let me know your thoughts on this. Local pilots who like to have this as BACKUP aircraft are welcome.
