BobDDuck said:Stuff we generally do that I haven't seen AWAC do:
-SE Taxi
-APU off after engine start or immediatly after take off
-APU on after landing (AWAC seems to turn it on at 10K)
Our FOM says we must land at full flaps unless they are broken. But then again, our approach speeds are a little bit faster then the jungle jet.stultus said:This is quite a tangent, but....combined with all the other fuel saving measures already mentioned, we're encouraged to land with a lesser flap setting so the power settings are lower on approach. Not sure how much fuel it saves, but I haven't seen the numbers.
-SE Taxi
-Take out the second coffee maker to save weight:insane:
Sorry, I'm in a list making mood!
wheelsup said:Would you happen to have a copy of that fuel report you can share with me? I haven't ever seen such a report, and I would be interested in seeing it (if you don't want to share I totally understand too, no biggie).
BobDDuck said:Our managment wouldn't actually give us a copy of the fuel report showing we burn more then everybody else. As far as I can tell there isn't one and they were just making it up to beat us over the head with. Our union did come up with a fuel savings plan which is mostly common sense stuff but does have some interesting things on it. If I can find a copy and get permission (it's not really public yet) I'll get you a copy.
As far as ground power at PHL... the ones on the jetways are the wrong HZ or phase I think. They were set up for the Dorks and Dashes which use a different setup then the RJs. Go figure. And good luck getting an actual GPU there. It takes hours to get one even when you call for it in range. With it being as hot as it is now we are leaving the APU running even in CLT when we do have ground power. However, once it gets colder I would bet they will be turned off.
I'm doing OE on the 700 right now (fun plane by the way) and the bleed system is controlled via the 6th and 10th stage which means that you can cool the plane even with the APU off. It's start the engines and turn the APU off, which I have forgotten to do on the last 3 legs.
As far as the lack of caring about fuel savings at AWAC... From the outside it looks as if it has to do with the senior guys still hoping that you go back into the UAL system and they can all go home. Not logical, but that's my take on it. I really think the whole fee for departure thing needs to go out the window and the contract companies start paying their own way. Won't happen of course, but's it's a nice pipedream.
Wow... it's amazing what 3 hours of airport appreciation will make you write.
ComplexHiAv8r said:There is an adult joke in there somewhere!!!! :nana2:![]()
BobDDuck said:As far as the lack of caring about fuel savings at AWAC... From the outside it looks as if it has to do with the senior guys still hoping that you go back into the UAL system and they can all go home. Not logical, but that's my take on it. I really think the whole fee for departure thing needs to go out the window and the contract companies start paying their own way. Won't happen of course, but's it's a nice pipedream.
CFIse said:It's easy to say get rid of fee for departure, to some extent I agree, but what would you replace it with?
wheelsup said:mainline feed (ie don't farm out the feeders, keep it all in house)
problem solved
wheelsup said:will it happen? no...but it's wishful thinking at least. I think the comairn strike probably put an end to that (I'm not upset they went on strike, they collectively raised the bar for which many good contracts since their time were based upon).
It's been breached already. Mesa is flying a few 900s (with only 88 seats) and PSA was just offered 20 900s with 20 more options. The problem? We are going to have to take a pay freeze to get them. The preliminary polling shows a pretty resounding no vote so we will see. The only positive is that Airways is trying to put more express flying in house. They just are insulting us while they do it.CFIse said:At least with USAir we've seen the line held at the 90 seater mark, although I'm not convinced we won't see that breached at some point and then mainline ALPA will again have to decide if they want the flying or the money, because they can't have both.
GaTechKid said:The same system Colgan has been operating under for years. They set the price for many of their routes and only collect the proportionate mileage portion that they fly of the entire ticket cost minus a US Airways booking fee, i.e. A passenger books a ticket from JST to ORD. Colgan flies the JST to PIT route which is ~60 miles. US Airways flies the PIT to ORD route which is ~600 miles (I'm guessing here). Colgan earns 60/660 of the ticket cost minus a booking fee.
At least that's how it was explained to me by my IOE captain...
