Funny, I was always taught to triple the outbound course for wind correction......
I'm not sure I understand this last part. One of the reason I draw the hold is that, once drawn (which includes my direction approaching the fix), the entry looks obvious to me.I'm a drawer, but after I draw it out I do this to figure out the entry:
The way I do holding is just picture where I'm gonna be when I hit the fix and my relation to the inbound course. When I reach the fix, if the inbound course is going to be ahead and to the left, parallel. Ahead and to the right, tear drop. If the inbound course is behind me at all, direct. And of course, when on the boarder between two, use the one that requires the least amount of turning.
	It depends on your speed. Lower speed such as a 172 you need a great wind angle correction. Higher speeds, you need less. So somewhere between 2-3 times works.As I understand it, you triple it to correct for the effect wind has during the turn outbound, the outbound leg, and the turn inbound.
This has worked in every time for me so far. It's not accurate enough to use on a test, but in the air it has worked every time. I'm pretty sure I got this method from someone on here.
I'm a drawer, but 99% of the time now I "draw" it in my mind, or "draw" it on the HSI in my mind. And my drawings look EXACTLY like what you just posted.I'm a drawer. I can draw the clearance as quickly as I can write it down so the method works for me. But it doesn't work for everyone - ever see people play Pictionary and see how bad some people are at drawing even simple relationships?
This is truly a "different strokes" issue.
I have a student right now who didn't need to draw it any more after the first time. OTOH, I still have a little difficulty visualizing the spatial relationships mentally, so continue to copy holding clearances in this graphic shorthand.I'm a drawer, but 99% of the time now I "draw" it in my mind, or "draw" it on the HSI in my mind. And my drawings look EXACTLY like what you just posted.
That was my preferred way of teaching it too. "Draw it until you don't need to draw it any more".
