I do pretty much the same thing as PanJet except I don't use my hands. In other words, I divide the heading indicator into three sectors to determine which entry to use, but I don't use my hands to remember how to divide it.
I tell students to mentally draw a line horizontally across the heading indicator. So if their heading is 360, mentally draw a line from 270 to 090.
Next, "twist" the line so it is raised 20 degrees higher on the side of the hold's direction of turns. So in the example I just gave, for right turns, mentally twist the horizontal line counterclockwise and raise the right side. The line would run from 250 to 070. Conversely, for left turns, raise the left side -- 290 to 110.
Finally, mentally drop a line down from the top of the heading indicator to the center of the instrument face.
Now the instrument face should be divided in to three sectors (two sectors on top and one big one on the bottom). If the OUTBOUND course for the hold falls in the smallest sector, it's a teardrop entry. In the middle-sized sector is a parallel entry. Largest sector is direct entry.
Why use the outbound course you might ask, instead of the inbound course? Because ATC oftentimes says the outbound course in your hold instructions. "Cessna 123, hold west of the ABC VOR along the 270 radial..."
There you have it--the outbound course in that case would be 270.
I should also stress I mainly use this method to determine the correct entry method, but not visualize the entire hold. I use it more like, "Ok, I KNOW this will be a parallel entry, now I need to visualize *why* it's a parallel entry." For visualizing the hold itself I usually do it in my head, but for new students sometimes I'll have them make a quick sketch on their kneeboard.
Why not have them make a quick sketch to determine the entry procedure to begin with? Mainly because I rarely see students draw holds perfectly to scale. What they draw on their paper might look correct, but in reality be 20 or 30 degrees different from what is actually happening, thus leading them to choose the wrong (or should I say, less efficient) entry method. By working backwards from what they know is the correct entry, then drawing out WHY it's the correct entry, they are less prone to mis-visualizing the hold.
As for night landings...umm...reference the instruments more, pay attention to the shape of the runway for determining approach angle, use VASI/PAPI systems if available, peripheral vision is extra important, unless on a narrow runway, begin to flare as the runway edge lights "rush up" to the sides, don't focus too much on where the landing light beam shines (look further down the runway), be aware of the common illusions such as black hole approaches or approaches to runways with significantly different dimensions from what one is used to landing on....shoot, I think you ought to open another thread for that question
