so i'm working through this commercial ticket and need some help with those lazy 8's, any advice from you CFI's would be greatly appreciated, right now i'm just doing them in a c-172, nothing special, i just want to get the basic idea of it down, but everytime i do it, i'm either too fast or too high from my inital altitude. any ideas?
Thanks,
Keith
So I started writing this nice long explanation for 8s on pylons
If you're continually too fast or too high, you might want to try knocking 100 RPM down or so. Also, when you get to the peak points (when you're at your 45' point), I always suggest a quick glance down at the attitude indicator, so you know how many degrees down you have to pitch. For example, if at the 45 degree point, you're 2 bars up, then at the 135 degree point, you should (briefly) be 2 bars down.
It's a tough maneuver and it takes some practice, so don't worry too much about it, just keep working on it and try to learn where your mistakes are being made. That, to me, is a better indication of ability, when someone can say "Well I ended up high because I had too much power in," or, "I didn't pitch down enough". If you understand how the maneuver works, flying it will become easier.
