Holocene
Not sure how heavy this plane was at the time, but with 3 people inside I would guess at least 2400lbs. The rough numbers not accounting for wind or slope are 900' ground roll and 1500' to clear 50' obstacle.
I've been out of flying for some time. Doesn't it seem like this was cutting margins too close, or has anyone successfully taken off in this distance at a similar weight?
NTSB Identification: ERA16FA161
14 CFR Part 91: General Aviation
Accident occurred Monday, April 18, 2016 in Westmoreland, NY
Aircraft: CESSNA 172, registration: N1863Y
Injuries: 2 Fatal, 1 Minor.
This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed. NTSB investigators either traveled in support of this investigation or conducted a significant amount of investigative work without any travel, and used data obtained from various sources to prepare this aircraft accident report.
On April 18, 2016, about 1910 eastern daylight time, a Cessna 172C, N1863Y, collided with trees and terrain during takeoff from Sophie's Choice airstrip, Westmoreland, New York. The private pilot and one passenger were fatally injured, while one passenger sustained minor injuries. The airplane was destroyed by a postcrash fire. The airplane was registered to a private individual, and operated under the provisions of 14 Code of Federal Regulations (CFR) Part 91 as a personal flight. Visual meteorological conditions prevailed at the time and no flight plan was filed. The flight was originating at the time of the occurrence, and was destined for Griffiss International Airport (RME), Rome New York.
Witnesses reported the pilot initiated takeoff to the east from the downsloping grass runway with about 1,130 feet of runway available. The flight became airborne when past the windsock located near the departure end of the runway and continued to the east. While flying past the departure end of the runway, a pilot-rated witness reported seeing the airplane bank to the right, then left and described it as "hanging on the propeller." While in a right bank, the left wing collided with a tree about 30 feet above ground level and the right wing collided with the ground. The airplane came to rest upright about 40 feet past the tree contact location, and a postcrash fire started shortly after the airplane came to rest.
