5.5 gallons (61 minutes) in a straight 800, and 10.04 gallons (85 minutes) in the 750/800/850/900 XP models. I THINK I remember being told that a full gauge may not necessarily indicate a full tank. If you have a truly full tank, you get something like 100 minutes of protection. The key is to not forget to reset the egg timer. The system runs at high flow for the first minute (maybe it's two) it's selected. If you keep running on high for one minute, and then one more minute, and then one more minute...well, you get the picture.
Prime it before EVERY leg. The check valves get weak and the fluid flows back down from the tail. Priming it gets it back up there and ready for use when you need it. It also lubricates the lines and cleans the bugs out of the pores.
