meritflyer
When determining yout top of climb for flight planning purporses, would you want to use the TAS or GS?
Casper said:TAS...especially if there is a chart in the AFM/POH. They do not take into account your GS.
You will probably not get an accurate checkpoint on the ground no matter what you do. The charts for light planes almost always have you climbing at Vy all the way to cruise altitude, which no one ever does. So why use the chart at all?SierraPilot123 said:I believe most POH's always use KIAS for the "time, fuel and distance to climb".
But at some point on your VFR nav log you need to account for the wind during the climb if you want to have an accurate checkpoint on the ground.
meritflyer said:When determining yout top of climb for flight planning purporses, would you want to use the TAS or GS?
wheelsup said:Honestly, IMO, all that really matters in xcty planning (outside of the checkride environment) is how much fuel you have on board and picking checkpoints that are easy to see/use.
