Can't you go 10 hours past if heading to a maintenance facility?
Ok, so I know you can not go past the 100 hour if your using the plane for hire. Lets say the airplane is on a 135 certificate. Can one use the airplane (not for hire) and go past the 100 hour? if not, anyone know where one can find documentation saying that?
I need some source. Chief pilot and Director of Maintenance are having issues with each other regarding this issue.
I don't think you're going to find this one explicitly. As the CP here says, "Not following the 135 rules when you're not 135 is like breaking the laws of Egypt when you're not in Egypt. Who cares?"
When you don't have passengers or cargo (other than comat), you're not 135, so how can you break a 135 regulation?[/QUOTE]
If I'm not mistaken, in this case that reasoning doesn't apply. The airplane is maintained under the certificate holder's approved inspection program, and therefore is maintained in accordance with it, regardless of whether or not it is being operated on a 135 leg.
My current employer is approved to overfly the 100hr. by its GOM, so the above scenario is really a moot point.
Best answer yet.
24/7, until the logbook entry is made and the FAA is notified, an airplane is always 135 regardless of who is flying or the purpose of the flight. There is probably a part in the GOM that references Opspecs Sect D that outline the inspection program. It's tied into the operator maintaining operational control of the aircraft.
It's the difference between operating a 135 flight and operating a 135 aircraft.
Scenario:
An owner has his Navajo on leaseback or leased to a 135 operator. He transfers operational control to the certificate holder. He has to be trained in and follow the admin procedures of the certificate holder. The aircraft does not have an approved MEL (it probably would, I know). He goes to some remote field in west BFE with his girlfriend and blows a tire. He cannot just get a local A/P to swap out the tire. He has to call back to the certificate holder, and they have to approve the person/facility conducting the maintenance. It's a 91 flight, but the plane is still carried as a 135 aircraft and listed in the certificate holder's Opspecs. Now, let's say it was a burnt out landing light. Can he legally just return home as is? Nope. 135.179 -- no MEL has been issued. Yes, the flight is flown by the owner, not for hire, etc etc etc. However, with no MEL every static wick, bulb, switch, and breaker has to be right. In a pure 91 operation, you are right. Blast off. But this aircraft is under the operational control and subject to the maintenance program of the certificate holder.
FAR 1.1 defines operational control as "the exercise of authority over initiating, conducting, or terminating a flight." While the owner is flying his own airplane, you're saying he has to get permission from the 135 certificate holder to initiate the flight just as if it were a revenue leg? If not, I say the owner has operational control for that flight, and it's part 91.
In essence, yes. 135.77. Once it is listed as a 135 aircraft, it remains a 135 aircraft until removed from the certificate/opspecs. During that time, the certificate holder maintains operational control of the aircraft. Operational Control has been big since the Challenger went driving into the warehouse across the street from TEB.
