Fuel requirement for IFR flight
mastermags
Well-Known Member *giggity*
Just a technical question. If you file an alternate in your flight plan even when an alternate is not legally required (weather better than 1-2-3), are you still required to have fuel to reach your destination, then your alternate, and then fly an additional 45 minutes?
No. 14CFR91.167.
91.167 says fuel requirements for flight in IFR conditions. If you are not in IFR conditions I cant see why you'd have to.
He didn't say he wasn't in IFR conditions.
If you are in IFR conditions and you actually file an alternate, I would say carry the fuel legally required (thinking in terms of what the FAA might say/ask during a ramp check or investigation).
Interestingly, you're never even required to file an alternate in the first place, no matter what the weather.
91.169 says otherwise!!
§ 91.169 IFR flight plan: Information required.
(a) Information required. Unless otherwise authorized by ATC, each person filing an IFR flight plan must include in it the following information:
(1) Information required under §91.153 (a) of this part;
(2) Except as provided in paragraph (b) of this section, an alternate airport.
(b) Paragraph (a)(2) of this section does not apply if :
(1) Part 97 of this chapter prescribes a standard instrument approach procedure to, or a special instrument approach procedure has been issued by the Administrator to the operator for, the first airport of intended landing; and
(2) Appropriate weather reports or weather forecasts, or a combination of them, indicate the following:
(i) For aircraft other than helicopters. For at least 1 hour before and for 1 hour after the estimated time of arrival, the ceiling will be at least 2,000 feet above the airport elevation and the visibility will be at least 3 statute miles.
Doh! :eek: I stand corrected! I must have been thinking of center-stored flight plans, where you don't have to add an alternate. Thanks Lloyd! Nevermind me, I'll stay out of the CFI Forum from now on... haha.
LOL . . . no, you can still come in here!:)
After 1630, next Friday, I may have to stay out of the CFI forum, too . . .
There's that other forum, though . . . :p
