killbilly
This is driving me nuts.
I've got a fuel pressure gauge which vibrates/fluctuates consistently to either end of the range, and the frequency increases with RPM. Fuel boost pump doesn't change the frequency.
I've got a checkride scheduled in this airplane and I'm going nuts trying to figure out if it's required.
There is no MEL for the airplane, and 91.213 indicates that if it's required by the type certificate, then it has to be operative, or at least determined to be safe with proper deactivation and placarding by a mech if it's not required by the sheet.
The POH doesn't contain a Type Sheet. The Limitations section of the POH lists all of the equipment, but a) the fuel pressure gauge isn't listed, and b) nothing in that section lists required vs. optional.
Google is failing me.
The engine is running perfectly fine. I am concerned that the DPE is going to look at this and say, "that's broken, and this airplane isn't airworthy."
He might also shrug and say, "eh - you have fuel flow on the other gauge, so you're okay."
Neither mech I spoke to this morning knows the answer off the top of their heads.
Thoughts?
Thoughts?
