Some driving tips I use to help increase mpg are... 1) timing traffic lights to keep my speed up to avoid having to re-accelerate, 2) drive the speed limit or the "sweet spot speed" for your engine/rear-end gear combination, 3) shift, shift, shift...get to final gear, 4) park in spots where I can "pull through" to eliminate the need to back out of a spot and reverse course, 5) use the minimal amount of steering needed to make my turns... the friction of turning causes deceleration and the need to re-accelerate, 6) pretend there's an egg underneath your accelerator pedal when you accelerate... squeeze it... don't mash it, 7) don't idle... just don't do it.
I don't have much input on the injector duty cycles of an Evo, but coasting is never really a good idea even if it did save you .2 mpg. That's my thoughts at least.
