Frontier Hiring
I'm skeptical about this one. While the closing date could be the result of copy/paste a better indicator is the job number which is how they track applicants. I don't think you can re-use a number - and this one 004591 is the same job number as the October job. So there's a good chance if you apply for this one it won't let you if you applied to the October one because technically you're still in the system even if they filled that class. I might try it out to see. That happened once before on a different job when I got a "You've already applied to this job!" error. Could be a test posting.
