It's a very easy to fly airplane. Trim is your friend though, as it is heavy on the controls, and can be hard to "un-stick" if you don't have it trimmed properly. Watch the CG. With two upfront, and full fuel, you will probably be out of CG. The systems are STONE simple. Where we run ours, 30"mp/2200 RPM will get you about 45gph and 16-170 true. 32"/2300RPM will get you about 48GPH and 180 true.
The only quirk I can think of handling wise is near the aft CG point in the -325CR I've flown, the thing can get pitch sensitve, and be hard to trim. Same with the -350, so I'd imagine the -310 is the same.
