aviatorx43
Can I do it if I don't takeoff/land on the water? I've done Internet searches and seen conflicting answers, and of course the FARs dont provide much clarity. Anybody know, or have a source at least?
You need the ratings for appropriate category and class on your certificate to match the airplane. i.e. ASEL, ASES, etc. So no, you can't do it.
Wrong. Everything I've ever seen says you can operate a amphib on wheels only with just a SEL rating. A quick reading over at the Seaplane Pilot Association seems to agree with this.
Yep, totally legal..
But be aware that an amphib usually sits pretty high. Takes some getting used to. Otherwise, climb in and go!
Message:
If you are licensed for airplane multi-engine land, can you legally
fly a multi-engine seaplane provided you only land and takeoff from
land? I realize other endorsements may apply such as complex and
high performance; but for this example, lets assume the pilot has those
too.
This topic has been heavily debated, I've found no official answers.
Thanks in advance
Mr. Adler,
Multiengine land (MEL) and multiengine sea (MES) are different classes in
the same category of airplane. Both require specific training, checking,
and certification. A pilot who does not hold the appropriate category and
class ratings may not act as a required flight crewmember in flight.
However, anybody may manipulate flight controls of any aircraft in the
presence of another appropriately rated pilot or flight instructor. Refer
to 14 CFR section 61.5 for details on categories and classes of aircraft. I
hope this information is helpful in your debate.
JAMES M. WILKINSON, PMP® | Assistant FSDO Manager | Grand Rapids Flight
Standards District Office
3196 Kraft Avenue SE, Suite 103 | Grand Rapids, MI 49512-2065 | Desk: (616)
974-2502 | Fax: (616) 940-3140
Yes.. it just becomes a complex airplane. You cannot log it as SES time. Have seen this done under Part 135 as well. The non SES rated pilot also had to abide by the wheel plane requirements for gliding distance to land etc. Also anything from a gear malfunction to bad WX that would necessitate a water landing would need to be a declared emergency.
If you hold a SES rating can you log SES time without logging any water landings, just taking off and landing on wheels (with an amphibian)?
I do understand that in the seaplane world all what counts are landings but I was just wondering..
An other quick question, assuming you do your SES on straight floats, I guess if you hold a Complex endorsement you can also fly an amphibian, right? Or because the actual water landing with an amphibian requires extra care you need to get checked on it. I`m getting my SES in the next months, finally, and I was asked if I want to do it on straight or amphibian floats. Is there any limitation if you ck on floats vs a "flying boat"?
