I did my MEI with Black as well back in Dec. 08'
He was a pretty cool guy after he starts talking to you and takes off his sandals and puts his feet on the table . A little intimidating at first, but he will get better. Make sure your IACRA is filed out correctly or your oral will start out pretty rough (as did mine). I went there with my AGI which helped me out tremendously. He asked if I had it and I said yes. He came back and said Great! You just knocked off the FOI portion and the lesson plan. SO, make the effort to get that before you go. We talked mostly about multi-engine aerodynamics, nothing more than what is in the piper seminole supplement. He had me do a weight and balance. We talked about things on the sectional and where we would be doing our training that day. You can expect a lot of breaks during the ground portion. About every 15 minutes he went for more coffee so use that time to look through some stuff if necessary.
He brings you out over the everglades to do most of the air work so keep your eyes open! I had never flown out of there so I asked him to do the radios for me and he was fine with that. So as we are flying out he fell asleep and then woke up about 10 minutes later and told me to teach him how to do turns around a point. We did stalls and single engine maneuvers. After the air work, we went to North Perry airport which is right out side of Lauderdale. We did a couple touch and goes there. We did short field t/o and landings there as well. We then went back to Lauderdale and he asked me if he could take the landing and of course I let him. Overall, the ground portion for me was about an hour and a half. The flight another 1.5
He is a pretty cool guy, knows his stuff obviously.
Good Luck!
