mrivc211
Enroute from SLC to PSC, Ding......flaps failed. Returned to the field. This is where it got interesting. I've done it in the sim a bunch, but in real life its much different. Plane, was easier to control, but the difference was in the sim you can nudge it down pretty good, in real life, a little too much nudging and you've got the FAA at your door step. It's a good thing we voted in ALPA for legal services. Luckily I won't need any. Anyways, on approach the RVR went down to 2400, 1200, 1800. Ref speed was 175 KIAS the whole way down. While on final we could see the runway just fine, the sun had just set, and when I got into the flare, I lost sight of the ground. One of those, you can only see lights but no ground landing. Well, if flaps are 45, speed is down to 130, that might be ok, but with flaps at 0, and ref speed at 175, once the air stops moving across the wing, PLAP! on the ground you go. So since I lost sight of the ground, its hard to judge when to let it sit, I noticed airspeed rapidly decreasing, and around we went. We gave it a second try.
Second time around, same thing, it wanted to flare forever. But this time we choose 34R with a little better vis for the touchdown. RVR was 2600, 1800, 1000. When we hit the end, which we used the entire runway, we found ourselves in 0/0 vis. Nearly mistook the taxiway for the edge of the taxiway. Made it back to the gate, safe, with no scratches, and no one hurt.
1.5 hour sit now, and off to FCA we go.
BTW-Don I returned your PM but i just read you can't get any. So send me your private email again.
