First Real Emergency
bjm
Here I am at 170 hours, and I haven't encountered an emergency situation (thank God) or even a scary situation. So I have a few questions for you guys...How many hours (or years) before your first real emergency? What was your first emergency, and how did you handle it?
Hopefully we can get some good, interesting responses here!
I had an electrical fire in the clouds about 10 miles away from the airport I took off from. I probably had 140 hours total time... if that. Smoke was coming out of dash pretty good. I killed the battery master and the avionics master quickly and assessed the situation. No more smoke! So, I turned everything everything off, radio's, transponder, etc. because I was going to try and turn things back on one at a time and hopefully have some form of navaid work. No luck... I turned the battery master back on and the smoke started again. There was no VFR overly close, and I knew the area where I was fairly well, so I chopped the power, descended... I gave myself an altitude I knew would be at least 400 AGL, and if I didn't break out by then, I was going to try something different... I didn't really know what, but I thought I could figure that out later. I broke out about 700 AGL, I knew exactly where I was and did some good ol' fashioned scud running. I made it back to the airport without a problem, gave flight service a call from the FBO to inform them of my situation, and all was good! I hadn't been in contact with ATC yet (I took off with a clearance void time), so I didn't have any explaining to do to them. Now I always carry a cell phone when flying... I figure calling ATC would be a good thing to do if in that situation again. Oh well, live and learn.
