troopernflight
I was told that this section is new and allows 2 pilots to log PIC at the same time. It looks like as long as the captain is an ATP or MEI, and you are flying right seat that you can log this as PIC (as long as you are rated for category/class). That's if you are doing an "approved pilot in command training program". Not sure what they are requiring specifically on that. Does anyone have any knowledge on what this pilot in command training program needs to consist of to be legit?
See section in bold:
(e) Logging pilot-in-command flight time. (1) A sport, recreational, private, commercial, or airline transport pilot may log pilot in command flight time for flights-
(i) When the pilot is the sole manipulator of the controls of an aircraft for which the pilot is rated, or has sport pilot privileges for that category and class of aircraft, if the aircraft class rating is appropriate;
(ii) When the pilot is the sole occupant in the aircraft;
(iii) When the pilot, except for a holder of a sport or recreational pilot certificate, acts as pilot in command of an aircraft for which more than one pilot is required under the type certification of the aircraft or the regulations under which the flight is conducted; or
(iv) When the pilot performs the duties of pilot in command while under the supervision of a qualified pilot in command provided—
(A) The pilot performing the duties of pilot in command holds a commercial or airline transport pilot certificate and aircraft rating that is appropriate to the category and class of aircraft being flown, if a class rating is appropriate;
(B) The pilot performing the duties of pilot in command is undergoing an approved pilot in command training program that includes ground and flight training on the following areas of operation—
( 1 ) Preflight preparation;
( 2 ) Preflight procedures;
( 3 ) Takeoff and departure;
( 4 ) In-flight maneuvers;
( 5 ) Instrument procedures;
( 6 ) Landings and approaches to landings;
( 7 ) Normal and abnormal procedures;
( 8 ) Emergency procedures; and
( 9 ) Postflight procedures;
(C) The supervising pilot in command holds—
( 1 ) A commercial pilot certificate and flight instructor certificate, and aircraft rating that is appropriate to the category, class, and type of aircraft being flown, if a class or type rating is required; or
( 2 ) An airline transport pilot certificate and aircraft rating that is appropriate to the category, class, and type of aircraft being flown, if a class or type rating is required; and
(D) The supervising pilot in command logs the pilot in command training in the pilot's logbook, certifies the pilot in command training in the pilot's logbook and attests to that certification with his or her signature, and flight instructor certificate number.
