So I've heard a lot on this board about people who decided to major in something other than aviation, or in simpler terms: decided to get a back up degree to fall back on in the case of a furlough or what not.
My question is: "Has anyone here ever had to actually fall back on their plan B non-aviation major? If so, how did it go? Was the transition smooth, or did you simply find yourself inside a hole that was deeper than you thought?"
The reason I ask, is because to me, it seems that even if you did invest the time and money to get a non-aviation degree and even if by chance you did find yourself in a position in which you felt the need to fall back on something, you wouldn't have much better luck and might even have less luck trying to find a job in an environment where there are much more people competing for the same job you hope will sustain you (financially) throughout your furlough.
