Looks like FAA Tech Ops employees, the ones who fix ATC equipment and NAVAIDS such as VORs and ILS, are being laid off. Expect to see more U/S NOTAMS in the system for longer periods (longer than the usual 30 days by default). Thank god the FAA finally learned what a GPS is and that you can use it to substitute a broken ground VOR with a GPS WPT. This should make the outages much easier to deal with. Well except if mx control put your GPS/FMS on MEL then ur screwed. Expect to see XXX NA EXCEPT FOR AIRCRAFT EQUIPPED WITH SUITABLE RNAV SYSTEM WITH GPS on a lot for airports as VORs break and no staff is available to fix them.
