Hey all. I fly a C-182 and C-206 for a local skydive outfit. We fly our airplanes a little unconventionally, on the edge, and certainly by the seat of our pants. Upon dropping our load, I pull the prop RPM out all the way and bomb down from altitude gradually reducing my MP as I go. Often times when hi on short final, I will push my prop in as it acts as a speed brake, otherwise will land with the prop still out (low RPM)
My question is this. In looking at the POH, under emergency procedures, engine failures to be specific, I would have expected to see a reduction of RPM to increase my glide distance. I did not however. Why is this? I suppose the only logical answer would be that once the engine quits, one is unable to move the prop.?? If this is the case, it would seem that if you have any warning while the engine is still running/sputtering, I would want to pull my RPM back as far as I could.
Anybody....Anybody....:bandit:
