sixpack
I have described two emergency scenarios below, in an attempt to solicit ideas and opinions about handling emergencies. Consider what you might do if you were in each of the situations described. Might lead to some useful discussions.
1. Total Electrical Failure on ILS
You're on the ILS at 2000' AGL just before FAF.
Weather is IMC down to ILS minimums.
Voltage drops from 12V to about 3V and your avionics are failing.
There's 50 amps indicated on both alternators of your small twin.
You can hear tower calling you as your COM2 goes in and out, but every time you key the mike the radio goes black. Nothing electrical is working.
You pulled every breaker, but you're still showing 50A each side.
What do you do?
2. IMC ENGINE FAILURE over MOUNTAINS
You're over the mountains, IMC, and your left engine goes out.
Troubleshooting failed, so you secure the dead engine.
You're call ATC, declare an emergency.
You cannot maintain altitude.
The second engine starts to fail.
What do you do?
What do you do?
What do you do?
