dasleben
That's just, like, your opinion, man
Alright guys, here's a situation I came across a few days back and thought I'd pose it to everyone. I'd like to see how many people handled it the same way I did. I won't say what I did yet, but I've been giving it a lot of thought and wanted some outside opinions.
Alright, here's the setup:
You're on a 7,000' runway with an accelerate/stop distance of right around 4000' on a dry surface. The current weather is 800/2 in moderate rain, and all runway surfaces are obviously wet (the performance charts do not address wet performance, only dry). The door warning system on the aircraft is MEL'd, with a previous writeup for the warning coming on in-flight with all doors secure. However, it's been your experience over the past two days of flying the aircraft that the warning system seems to work properly.
As you add power for takeoff, all warning lights are extinguished. Accelerating through 80 knots, however, the door warning illuminates (seen from behind the "inop" sticker), indicating that any one of four cabin doors may not be secure. That said, none of the doors have yet come open.
Do you:
Reject the takeoff?
Continue the takeoff and return to land?
Continue to your destination?
Other?
By the way, if it factors into some peoples' decisions, the aircraft in question is not equipped with a pressurization system. Filed cruising altitude is below 10,000'.
Do you:
Reject the takeoff?
Other?
