I'm a little confused by the holding pattern instructions. Does ATC give the inbound course or the outbound heading in holding pattern?
The AIM says that ATC should give the inbound course, where CFIs say that ATC gives outbound heading.
"Hold west of PVU VOR on the 210 radial"
Do I draw 210 as and outbound heading or an inbound course?
Holding instructions should include the following: Fix; General
direction of the side of the fix where you'll hold (
N,SE, SW, etc of the FIX); Radial (specific radial on which you will hold (this is the radial extending from the fix)), leg (length or time), turns (L if non-standard).
ATC is supposed to give you all this info, but sometimes doesn't.
It can be especially confusing if you are instructed to hold at a DME fix on a radial off a VOR. This is where the direction from the FIX can be especially helpful. Consider a hold at a fix 15DME on the 230R of the ECA VOR. The fix is on the 230R ECA, so the
fix will always be SW of the VOR. But that is not really what you care about. You care about the fix. More specifically, you care about on which side of the fix you be holding.
Why? Because the side of the FIX on which you be holding determines what direction you will need to fly to get to the fix (inbound course) before beginning your turn to the outbound leg of the hold.
If, for instance, you are told to hold NE of the ECA R230 15DME fix, you are being asked to hold
NE of the fix.
But the FIX is always SW of the ECA VOR. Why? Because it's on the 230R from the VOR.
But because you are asked to hold NE of the FIX (not the VOR), you will need to fly SW on the 230R to get to the fix. So your inbound course to the fix will be 230 degrees since you were asked to hold on the 230R ECA and the FIX is on that 230 degree radial.
If instead, you were instructed to hold SW of the FIX, you would still be SW of the VOR on the 230R, but now you would
also be SW of the 15DME FIX. So to get to the FIX, you would need to fly NE to get to it. Since you were asked to hold SW of the FIX on the 230R, you will now fly the inbound course to the FIX on the reciprocal course of the VOR radial. You will be flying NE on an inbound course of 050 (the reciprocal course of 230).
Clear as mud?
