BrianNC said:Do any of you freight dawgs with no GPS or radar in your planes use a yoke mount GPS with or without nexrad?
I'm not a freight dawg, but I personally use one. It being on the yoke doesn't bother me at all.desertdog71 said:Wrong section for me to post in, but I tried on of those Yoke mounted GPS deals, and well. It was in the backseat by the end of the taxiway. I just can't deal with crap on the yoke.
BrianNC said:I'm not a freight dawg, but I personally use one. It being on the yoke doesn't bother me at all.
The intent of the question really was to see if those that are flying in a lot of weather, etc., with minimum equipment use some things on their own to make up for it.
I thought even the FAA said a GPS is all right for situational awareness, even in IFR, as long as you are using it for situational awareness alone and not trying to to approaches with a non-IFR cetified GPS.EatSleepFly said:You can get in pretty big trouble with the FAA if they catch you using a handheld GPS under 135, especially IFR.
I'm sure a few people use them, but I hope that "hide GPS deep in flight bag" is part of their approach flow.
desertdog71 said:I am sure alot of them do, its great for Situational Awareness if nothing else.
BrianNC said:I thought even the FAA said a GPS is all right for situational awareness, even in IFR, as long as you are using it for situational awareness alone and not trying to to approaches with a non-IFR cetified GPS.
John Herreshoff said:Even for situational awareness? I'd be hard pressed to be flying around in mountains without a GPS on board and no GPWS either.
Texasspilot said:There was a guy who had on with the radar weather on it and learned to fly in florida using it to navigate around t-storms out there but when he got into the midwest and tried it he ended up with chunks out of the nose from the hailstorm he flew the plane through.
John Herreshoff said:I'd be hard pressed to be flying around in mountains without a GPS on board and no GPWS either.
Trybysky said:I'd like to see where it says you can't use it too.
I guess that alone would be why you technically can't use one even VFR. Well, unless your specific company approves of them, that is.The Man said:§ 135.144 Portable electronic devices.
(a) Except as provided in paragraph (b) of this section, no person may operate, nor may any operator or pilot in command of an aircraft allow the operation of, any portable electronic device on any of the following U.S.-registered civil aircraft operating under this part.
(b) Paragraph (a) of this section does not apply to—
(1) Portable voice recorders;
(2) Hearing aids;
(3) Heart pacemakers;
(4) Electric shavers; or
(5) Any other portable electronic device that the part 119 certificate holder has determined will not cause interference with the navigation or communication system of the aircraft on which it is to be used.
(c). The determination required by paragraph (b)(5) of this section shall be made by that part 119 certificate holder operating the aircraft on which the particular device is to be used.
(2) Hearing aids;
mtsu_av8er said:[/b][/i]Hmmm . . . need we hide the IPODS, CD players, timers, etc?
EatSleepFly said:I'm not the FAA, knock yourselves out. You can use whatever your company says you can use. I'm sure calculators, timers, and headsets would fall into that category. I merely took an educated guess at which "written rule" people are thinking of when they say handheld GPS's aren't allowed.
Also, an Ipod would probably fall under "portable voice recorder," which is on the list of exceptions.
