kryan11
So I have a scenario that I've had two different answers to and can't find the "answer" to it. I'm trying to clear it up, basically it has to do with the cardinal directions given when being told to hold around a non published DME fix. Do the Cardinal Directions clarify which side of the fix to hold on? Or do they mean to just hold that direction inbound of the fix and then you use the directions of left or right turns to decide which way to turn?
Here's the clearance:
Mesquite 123 from the PHX VOR fly to the TFD VOR and intercept the 12 DME arc to the SE. At the 010 radial turn inbound, then at 10 DME hold SW.
So you fly past the 10 DME fix make a parallel entry, do you hold in a non standard pattern on the west side, or do a standard pattern on the east side?
