CoffeeIcePapers
Well-Hung Member
Can anyone point me in the right direction, or is this even possible? I am mainly interested in building something that would allow me to get ADS-B weather and broadcast it via BT, but not pay $700.
Software defined radio?Can anyone point me in the right direction, or is this even possible? I am mainly interested in building something that would allow me to get ADS-B weather and broadcast it via BT, but not pay $700.
@drunkenbeagle have you looked into anything along these lines?
I thought of you as soon as I saw Rasberry PI 8)Yeah, I have. Realized that it was enough work that I would not bother building and debugging something like that for fun.
A VOR, DME or GPS receiver is simple enough to design and build yourself. ADS-B, not so much. Mostly, as has been pointed out, there are a lot of protocols to understand/reverse engineer.
Shouldn't you be drinking???
@Rocketman99 needs to work on this tolerance for NJC13?I think @Rocketman99 still needs time to recover.
Are you trying to feed data to a third-party program like Foreflight?
I didn't do a ton of reading on it but it appears FIS-B is on a separate band called UAT. Everything that people appear to be building to this point is 1090ES which seems to be reserved to the big boys (jets) and doesn't include FIS-B. There is an FAA document describing UAT located here... http://adsb.tc.faa.gov/WG5_Meetings/Meeting1/UAT-WP-1-09.pdf
Once you get the data though I'm not sure what you're going to do with it unless you build up your own GUI. My few quick searches about Foreflight and Garmin indicate that they're not leaking the secret sauce to how they're getting the data over Bluetooth. Protocols can be reverse engineered but dang that would be a TON of work.
If I ever get this Raspberry Pi working in my car with Bluetooth maybe I can shift some focus to this project. At least get the SDR to pull in the data. Maybe Foreflight will eventually put up an SDK for their Bluetooth stuff.
The FIB-B out on the 890hz UAT frequency requires a UAT equipped aircraft to be broadcasting to the ground station before it broadcasts any FIS-B data.
I suspect your time - at the end of the project - is worth the $700 it would take to buy an ADS-B unit.
