You are flying to your destination when you go missed and decide to divert to your alternate. When you land, the airport tells you "XYZ 1234 hold short of A on Z." When you inquire about how long they are gonna hold you there they say "not sure but we will call when you are good to taxi" Fast forward a few hours and its now been 2 hours and 45 minutes on the ground. You shut the engines off and are running the apu to keep the pax happy but they are annoyed regardless. You then get the DING DONG from your EICAS with FMC MSG. You look and its from the dispatcher. This is what it says.
Now seeing this and knowing that management must be pretty desperate to have pressured you dispatcher to tell you to pop slides and evacute due to you almost timing out the 3 hour DOT rule WHAT WOULD YOU DO?? *this actually happened to one airline earlier this year. Heres what they did, what would you do.
WHAT WOULD YOU DO??
more info can be found here: http://news3lv.com/news/local/passe...-diverted-to-mccarran-on-houston-to-la-flight
WHAT WOULD YOU DO??
