NewsBot
Administrator
Boeing Company Saint Louis, Missouri:
Location Saint Louis, MO
Security Clearance Required? Ability to Obtain Interim and/or Final Clearances (Post Start) - US Citizenship Required
about security clearance definitions
Position Description
Provides operational suitability guidance as part of a UAS development team. Plans and remotely conducts ground, flight and developmental test flights for experimental, prototype and production UAV aircraft and control stations to verify aircraft performance, stability/control, and system functionality. Develops and coordinates flight test plans, mission and contingency plans, procedures and techniques to achieve qualification or certification. Plans and develops technical reports and flight reports. Evaluates flight data and participates in UAV aircraft and control station design and development and recommends changes to design based on naval carrier operational considerations. Participates in development of naval-specific UAS operational procedures and systems. Collaborates on marketing, evaluation and demonstration activities for customers; conducts familiarization, demonstration and training flights. Job requires FAA Commercial Pilot Instrument certificate.
Competencies
General
[ + ] Adaptability
Fully understands changes in own and fellow senior employees’ work and situations; is frequently called upon to explain the logic or basis for change to other employees; is generally seen as an expert on information about changes affecting own and fellow senior employees’ jobs; occasionally mentors fellow employees around the change. Treats changes and new situations as opportunities for learning or growth; focuses on the beneficial aspects of change; speaks positively about the change to fellow senior employees and external customers. Quickly modifies behavior to deal effectively with changes in the work environment; readily tries new approaches appropriate for new or changed situations; does not persist with ineffective behaviors.
[ + ] Contributing To Team Success
Consistently makes procedural or process suggestions to work group members, fellow project leads, other internal employees, and external customers for achieving team goals or performing team functions; provides necessary resources or helps to remove obstacles to team accomplishments. Listens to and fully involves others in team decisions and actions; values and uses individual differences and talents. Shares important or relevant information with the team. Adheres to the team’s expectations and guidelines; fulfills team responsibilities; demonstrates personal commitment to the team.
[ + ] Planning And Organizing
Identifies more critical and less critical activities and assignments; adjusts priorities when appropriate. Proactively determines project or assignment requirements by breaking them down into tasks and identifying types of equipment, materials, and people needed. Effectively allocates appropriate amounts of time for completing own work; avoids scheduling conflicts. Is an expert at taking advantage of available resources (individuals, processes, departments, and tools) to complete work efficiently; coordinates with internal and external partners. Uses time effectively and prevents irrelevant issues or distractions from interfering with work completion.
[ + ] Systems Thinking
Consistently evaluates job tasks and processes on how well they help meet team objective(s); identifies non-value-adding components and barriers. Formulates change strategies; frequently seeks input from other project leads and internal employees to evaluate options for change and encourage buy-in. Makes appropriate changes to job/role structures and processes by communicating effectively and focusing on new skill development. Uses extensive measurement systems to monitor the implementation.
Technical
[ + ] Aircraft Performance Data
Basic - Extensive, specialized knowledge of aerodynamic and propulsion principles and their application in developing aircraft performance data. Extensive, specialized knowledge of associated regulatory requirements and related impact on aircraft performance data. Utilize this knowledge to resolve customer issues, to design and develop products, and to mentor less experienced personnel.
Preferred -Advanced, expert knowledge of aerodynamic and propulsion principles and their application in developing aircraft performance data. Advanced, expert knowledge of associated regulatory requirements and related impact on aircraft performance data. Utilize this knowledge to resolve customer issues, to design and develop future products, to mentor colleagues, and to represent the company at an industry level. Recognized as company expert in a specific aircraft performance discipline.
[ + ] Aircraft/Weapon Design
Basic - Extensive knowledge of engineering design requirements for aircraft, weapons systems, and crew stations and an ability to use in communicating with engineering.
Preferred -Advanced knowledge of engineering design requirements for aircraft, weapons systems, and crew stations and an ability to use in communicating with engineering.
[ + ] Aviation Ability and Knowledge
Basic - Advanced knowledge and ability to utilize crew resource management, weight and balance calculations, navigation procedures, airspace, meteorology, aircraft performance data, communication operations, flight planning, industry regulations, and pilot aviation skills to include: instrument, night, formation, and cross-country flight instruction, flight planning, flight test profiles, and functional check flights.
Preferred -Extensive specialized knowledge and ability to utilize crew resource management, weight and balance calculations, navigation procedures, airspace, meteorology, aircraft performance data, communication operations, flight planning, industry regulations, and pilot aviation skills to include: instrument, night, formation, and cross-country flight instruction, flight planning, flight test profiles, and functional check flights.
[ + ] Flight Test Operations
Basic - Advanced knowledge of aircraft flight crew operations, flight deck design philosophy, flight deck/pilot interface, flight test requirements and procedures and customer requirements. Knowledge of how the customer flight crews operate aircraft during day to day operations, including typical airline/military flight operations and all normal and non-normal operating procedures and checklists. Knowledge of the Air Traffic Control environment and how aircraft are routed through the air traffic environment.
Preferred -Extensive knowledge of aircraft flight crew operations, flight deck design philosophy, flight deck/pilot interface, flight test requirements and procedures and customer requirements. Knowledge of how the customer flight crews operate aircraft during day to day operations, including typical airline/military flight operations and all normal and non-normal operating procedures and checklists. Knowledge of the Air Traffic Control environment and how aircraft are routed through the air traffic environment.
[ + ] Flight Test Reporting
Basic - Advanced ability to document flight test and communicate the data clearly to the appropriate audience verbally or through technical reports.
Preferred -Expert ability to document flight test and communicate the data clearly to the appropriate audience verbally or through technical reports. Uses knowledge to recommend disclosure of aircraft deficiency to regulatory agencies.
[ + ] Military Aircraft Cert & Perf
Basic - Extensive knowledge and ability to develop proposals for multiple new projects based on regulatory requirements (e.g., FAR, JAR, Mil-Spec, etc.) without existing proposals as reference or examples.
Preferred -Advanced, expert knowledge and ability to apply in-depth technical and theoretical knowledge of the regulatory requirements (e.g. FAR, JAR, Mil-Spec, etc.) to develop proposals for multiple new projects.
Basic Qualifications For Consideration
Do you have an FAA Commercial/Instrument rating?
Do you have, or can you qualify for a FAA class 2 medical certificate?
Are you qualified or have you previously been qualified as a pilot or NFO in a US Navy, carrier-based aircraft?
Typical Education/Experience
Level 4 - Technical bachelor’s degree and typically 9 or more years’ related work experience or a Master’s degree with typically 7 or more years’ or a PhD degree with typically 4 or more years’ related work experience or an equivalent combination of education and experience. A technical degree is defined as any four year degree, or greater, in a mathematic, scientific or information technology field of study.
Level 5 - Technical bachelor’s degree and typically 14 or more years’ related work experience or a Master’s degree with typically 12 or more years’ or a PhD degree with typically 9 or more years’ related work experience or an equivalent combination of education and experience. A technical degree is defined as any four year degree, or greater, in a mathematic, scientific or information technology field of study.
Other Job related information
Position will require travel. Applicants must have an FAA Commercial Pilot Instrument Certificate. Applicant must have operational experience with Navy carrier controlled airspace and deck operations. Highly desired that applicant have completed a DOD approved test pilot school. Highly desired that applicant have operational experience in navy strike and/or ISR aviation. Desired that applicant have experience in development and test of UAV aircraft.
Continue reading...
Competencies
General
[ + ] Adaptability
Technical
- Business Unit Engineering Ops & Tech
- Division Boeing Test & Evaluation
- Program Chief Test Pilot
- Job Type Non-Management
- Experience Level Career/Experienced
- US Person Status Required? Yes
Continue reading...
