FAA has released the transcripts/recordings.......
http://www.faa.gov/data_research/accident_incident/2009-10-23/
You will NEVER hear the CVR.
Only transcripts of the CVR.
Also, the FAA is skirting a thin line here. This is an open NTSB investigation and they should be the ones putting it on the public docket before the FAA is trying to get a leg up on this one. The problem is the NTSB can't really tell the FAA to stop.
That's what I meant, transcripts not audio.
The FAA needs to lose the ego and let the NTSB conduct its investigation. I am so sick of the FAA allowing the USA TODAY to draw conclusions about subjects journalism majors can't comprehend.
JEP,
also one thing that is being talked about behind the scenes is the FAA dropping the ball yet again in failing to notify NORAD. They are terrified about what's coming down the pipe about this. Referencing that, they are deliberetly diverting attention away from that by creating a media frenzy. Heads are going to roll at the FAA forthis and they're just trying to confuse the public on the real problem.
How is the FAA showing an ego here? All they have done is released transcripts of the communication between ATC and the a/c. How is the FAA allowing the USA Today (or any paper for that matter) to draw conclusions? It is public information and people (media) can do with it whatever they choose. There are obviously people that don't agree with it, but it is what it is..Public information and right or wrong, the public has a right to it. Also, how does the fact that this information is out matter, does it impact the ability of the NTSB to do their investigation? It's not a jury trial where jurors may be influenced by reading the transcripts.
I will defer to Mark on what he thinks the FAA should or shouldn't be doing, but as he mentioned, like it or not, there is not much the NTSB can do about it.
poster1 said:As you know I'm a long time fan of the NTSB, but I hope in this case they don't accidentally stop some really important voluntary safety programs such as ASAP and FOQA.
poster2 said:Given the nature of the incident, it's being handled pretty much like any other. Pertinent factual data is frequently released early in investigations. In this case, the most pertinent factual data available is the crew's explanation of what happened. NTSB interview summaries are always part of the public accident docket. I don't see much reason to sit on them in this case. I keep hearing that ASAP/FOQA stuff, but those processes are entirely separate from NTSB investigations, and as far as I know, none of the information used in this came from ASAP.
There were ASAP reports filed on this incident. The ASAP MOUs are clear that all information in ASAP is to be kept confidential unless the ERC denies the ASAP submission. That's not what's happened here. This whole thing has been a complete bastardization of the ASAP process, which is supposed to be sacred.
While I agree that the FAA has totally fubar'd this whole situation, NWA188 has been excluded from ASAP due to admitted intentional violation of SOP's.
