ZapBrannigan
If it ain’t a Boeing, I’m not going. No choice.
Ok weather whizkids. Need your help here.
Let's say you're sitting at a Podunk airport with no deicing equipment and no weather observer.
AWOS says the temp is 0 degrees with light rain.
Is it fair to assume that any liquid precipitation falling when the temperature is 0 or less is FZRA or FZDZ?
Therefore, if my company SOP says thou shalt not take off in FZRA, it is fair to put it in the hangar if its raining with a temp of 0 or less?
Technically FZRA is liquid until impact with a below freezing surface -- but since we can not measure the skin temperature of the aircraft all we can go on is OAT. Even an airplane that has been sitting in a warm hangar overnight has a "holdover time" that can not be measured because we don't know how rapidly the skin temperature will fall below freezing.
And if i'm way off base here, then how would you determine FZRA while sitting in Podunk under those conditions?
