Not every aircraft has ACARSIf it landed wouldnt it show it on ACARS via OOOI?
Even if the airport doesnt have ACARS, the aircrafts WoW sensor should trigger the On ground time when it lands.and not every plane that has ACARS has a unit that works. nor does every airport have ACARS.
ACARS is NEVER deferred.and not every plane that has ACARS has a unit that works. nor does every airport have ACARS.
Almost.. Couldn't locate an overdue flight and ATC said they never landed. I got ahold of the crew via their cell phone as they walked through the terminal :-|. I would have of they didn't answer... That's the closest I ever came to declaring.
where did they land if ATC said they never landed? By overdue do you mean it went over on its arrival time and it disappeared from your radar?
OPS wasn't answering their phone either.. It was late at night and not even the manager answered their phone.But still unless its a uncontrolled airport, SOMEONE must have seen that plane land. tower, ground, even the ramp guys.
I would have the local LEO do an airport inspection before I'd declare an emergency. Honestly, what does declaring an emergency do for you on an overdue aircraft? Probably gets local LEO out to do a airport inspection to look for your plane. Pretty much the same thing. If this is a 121 crew who forgot to close their flight plan and they don't answer their phone I'd talk to the hotel (hotel van driver) for an update. Calling a crew who's caller ID will show the airlines number is a good way to get a crew who is off duty to ignore you. It is most likely skeds wanting you to reposition to Bend, OR on a 91 leg giving you a 15 hour day. Screw that.
I've never had problems getting the crew to pickup. Left a VM a couple of times but they usually call back by the time I hang up.The crew answered their phone so apparently it worked.
