splash
your social justice comic center
I am lost in language or time here.
The Aircraft Technical Dictionary (3rd edition) by Jeppesen defines current limiter: A device which limits the generator out put to a level within that rated by the generator manufacturer.
However, the 1900 manual figure 7-1 shows a symbol of a current limiter (or isolation limiter) and also states: this acts as a large, slow blow fuse.
Someone tells me after turning on each generator checking each bus with the overhead rotor dial is called the "current limiter test". Based on my research I'm not sure if I can agree with this. Durring this test I believe you are only checking to see if power is being delivered to the 4 busses, no? Are the current limiters not a part of the GCU? Are these "slow burn" fuses the old way of limiting current? I can't find anything in the manual or the check list that calls this a "current limiter test". Ugh. What is this dude talking about?
