CS Props on a Single
C150J
Hi all -
If oil pressure is lost on a single with a constant speed prop, it GENERALLY goes to a high RPM setting instead of a full-feather (like twins), correct? If so, is the spring/nitrogen chamber BEHIND the hub and the oil reservoir in front of it?
Thanks!
J.
If you lose oil pressure in a single the resistance from the relative wind will force the prop into the low pitch/high RPM setting. The nitrogen/springs is only for multi-engines that need to overcome the relative wind and move the prop to the feather position.
EXCELLENT. Thank you!!!
Just to clarify,
There still is a spring in a single engine C/S prop. It's is just like you said, backwards from the design of a multi.
USMCmech said:
Just to clarify,
Great to know - so is there a reservoir for the oil somwhere in the hub, pushing TOWARDS the engine (high pitch, low rpm setting). Thanks!
J.
