cross-country time
ZUM
In terms of building cross country time for the instrument rating, does the solo XC time earned during PPL training count toward this time? And also, would it count if one were flying to an airport that is over 50nm away but stopping at an airport or two along the way that would result in a less than 50nm distance between any two airports along the route?
pilot602
Yes. Dual XC flights during your private training do not, however. Or at least that's the last understanding I had of hte matter.
As long as you have one airport that is 50nm+ away from your point of origin it's a XC. Not much of a XC, but the FAA says it is.
cime_sp
I seem to remember it being the first point of landing needing to be 50 nm away. If that's the case it would not count.
Buzo
All PIC x-country counts. As long as you make a landing at an airport 50nm away from the original point of departure it counts as X-C. You can stop every ten miles if you want to.
Eagle
Xcntry is anytime you land somewhere different than you took off, even if it is a mile away.
Each rating has a specific requirement about which Xcntry they will accept. ( that is the 50 miles or 300 miles etc...)
juskl
And for a real brain teaser. For the Commercial, you need a 300 NM trip with at least 3 landings and the first being at least 250 straight line from departure point. Now if you go 250 one way, don't you think you would need to come back 250?????? Thus totaling 500. Is it me or was someone lacking sleep when they wrote this?
Eagle
not if you are sharing the ride with another pilot who wants to fly back for his 300 miles.
juskl
Can't. Per the regs it has to be solo. I was actually planning a nice trip to Carlsbad, Ca for a weekend. But was told the wife could not go (or anyone else for that matter) due to this technicality. Kind of dumb I think. Oh well. I will do what they tell me to do.
Wolverine
It could be that they are allowing pilots to complete the requirement without completing the entire flight, just in case something happens. There's a number of reasons why someone couldn't make the return trip home right away: storms popping up on the route home, mechanical problems, fatique, etc.
And, with that little caveat, pilots can spend some time at the destination and get a little pleasure out of the trip, rather than just fueling up and flying back home.
DE727UPS
Wow...
I agree the solo (PIC) cross country time counts towards the instrument rating.
I disagree that you can make a landing until you've reached at least 50nm from your point of departure....no landing in between.
The whole point of cross country time is to get experience navigating a "long" distance away from where you take off from....not landing at an airport every ten miles. I've always trained,and been trained,that you had to have a 50nm hop between points to consider it a cross country (pvt, comm, ifr). Anyone had the FAA or a DE not say anything about a cross country where you landed somewhere before a 50nm distance? Gawd, this stuff can get confusing....
CRJwannabe
Our DE would laugh in your face and send you packing if you told him that you landed on your way to the airport that was "more than 50nm away from the original point of departure". I agree with DE727UPS, the point of the cross country would have been missed if you thought it was O.K. to land everytime you felt like checking out a new runway. Go the true straight line distance, don't stop, and you will be a better pilot for it and you won't have to worry about a DE sending you out to RE-FLY the cross country under their stipulations.
Alchemy
Yeah, for my commercial single engine, my long cross country was as follows:
AUS-LZZ 44 NM
LZZ-MAF 216 NM
MAF-AUS 257 NM
Took the checkride last month and the DE didn't say anything about the first leg being less than 50 NM. I don't know if he looked close enough to realize, and I certainly wasn't going to ask him about it right there.
DE727UPS
Comm X-C
"61.127(a)4(i) One cross-country flight of not less than 300 nautical miles total
distance, with landings at a minimum of three points, one of which is a
straight-line distance of at least 250 nautical miles from the original
departure point."
You were okay in that your total distance was over 300 and one leg was over 250. It's okay that you had a 44nm leg.
DE727UPS
Just so we understand each other...
Example 1: You takeoff from airport A and fly 20nm to airport B and land. You takeoff from airport B and fly 40nm to airport C and land. It's 55nm, straight line, from airport A to airport C. You leave the plane at airport C and drive home cause the FAR's are so stupid. This trip does not qualify as a X/C flight for the instrument rating, in my book.
Example 2: You fly the above trip outbound but on the way back fly direct from airport A to airport C, which is 55nm, and land. I'm not completely sure, but I think this whole trip, all three legs, count as a X/C flight for the IR because one of the legs was over 50nm. It's a grey area for me because I've never done it that way before but after reading the reg, it seems like it's okay.
Example 3: You fly from airport A to airport C and land, which is 55nm. Then, you turn around and fly back from airport C, to airport A, and land, which, magically, is still 55nm. This trip counts, for sure, as a X/C flight for the IR. This is the way I trained and the way I train. I dare say, this is what the FAA expects and was the meaning and intent of the rule. But...If there are CFI's out there that are doing things differently and have the DE's blessing, I'd love to hear about it.
E_Dawg
Moderator
I have. Even now I probably don't have 50hrs of XC time if I didn't count flights where I stopped somewhere along the way.
I took the FAR word for word... fulfilled the requirements; and all the DE did was check under the PIC XC column for 50hrs.
And I personally think it's made me a better pilot. 50nm isn't all that long in the first place, but by stopping at a third airport on the way I gained the experience of talking to different towers, planning more arrivals, and having more fun!
DE727UPS
After spending hours researching the question of X-C time time tonight. I've come to this conclusion....
To count as a X-C flight (for the IR), one leg in a series of legs must have been at least 50nm. You can takeoff on a X-C and make several landings at airports less than 50nm apart but one of the legs must be 50nm for the whole thing to count as a X-C per the regs. A DE would have to look hard at your X-C flights to catch this but the CFI who signed you off should know better.
FlyguyEd...look at your logbook again. If you have logged X-C flights where you never had one leg of at least 50nm, and your DE never said anything, then I'd say you were lucky and forget about it. I'd also say you weren't qualified to take your IR checkride and that your CFII and DE missed it or misunderstood the regs. These things happen and I'm glad this thread popped up or I never would have thought to do the research.
Alchemy
I agree with you DE727UPS. I typically do not log a flight as cross country unless the straightline distance from the first takeoff to the first landing is 50 NM or greater. However, for some reason I overlooked the 44 NM leg of my commercial cross country and didn't notice there might be a discrepency until after I had completed the flight. Normally I would make sure every leg was at least 50 NM just from force of habit, although it is apparant that the definition of logable "cross country" varies depending on what rating you're working on. What criteria would potential employers consider loggable as cross country, if they even care about cross country time at all?
On my commercial flight, you say you would log the first 44NM as cross country if the time were being applied to an instrument rating, because at least one portion of the flight was greater than 50 NM straightline distance. Sounds about right to me.....
