Philip said:I seem to remember from a systems class I took that the CRJ doesn't have any anti or de-ice on the tail. 2 things, did I misunderstand? Second, why doesn't it?
but why?Doug Taylor said:Probably didn't misunderstand. The 727 didn't have any tail de-ice either if I remember correctly.
And probably doesn't need it.
someone around here must know. Plenty of guys with CRJ types bouncing about.Doug Taylor said:Design! You'll have to probably ask someone that's a little more current in aero than I.
Turboprops, however, can build bone-chilling amounts of ice.
I wish I had a digital camera back in my BE-1900D days, the amounts of ice that accumulated on unprotected surfaces on the aircraft was incredible. Sometimes to the point that some of the other pilots on the ramp in MKE would walk over and go "Holy *blank*!"
BobDDuck said:No CRJ type but.....
Well, you know how everybody says you could teach a monkey to fly a CRJ? You could, if the plane didn't already have a monkey working on it. Most CRJs come with a factory installed Deice monkey. Right above the APU firebox there is a small box that is home to the monkey. There are ice detectors on the top of the tail and when they detect ice, the monkey comes out of his box (he wears a parachute just in case) and uses to rubber mallets to knock the ice of the surface. He then goes back into his home which is kept warm by the APU and is linked to the packs for pressurization. As far as I know you can MEL the deice monkey only if you're route is known to be VFR and at no point are you more the 50 miles from a suitable alternate.
Seriously? It probably has to do with the angle of the control surface to the relative airflow that prevents ice from forming.... but doesn't the monkey sound so much better?
BobDDuck said:Brian, it may not be installed on your airplanes. It might get too cold on the ramp overnight at some of the outstations for the monkey.
CFIse said:1) You did not misunderstand. No anti/de-ice on the tail.
2) We were told "it doesn't need it and I've never heard of anybody having any problems" - so as to the WHY, you got me.![]()
Philip said:that's the same thing they told us in class. There MUST be an explanation.
mtsu_av8er said:It's the same reason cars don't have windows at the bottom.
There's just no need . . .
