SlumTodd_Millionaire
Most Hated Member
Hope this helps and by the way, try bringing those numbers up with management if you haven't already. Maybe, just maybe, they haven't thought of it yet. Good Luck.
He works for Pinnacle. Any suggestion from a pilot at Pinnacle is immediately discarded by management, no matter how good of an idea it is. If they didn't think of it themselves, they don't want to hear about it.
I am not proposing to fly any slower overall... Cruise at .74 is still on the agenda (as much as going faster is always better for the psyche). The difference in the climb (typically only 2-3 min change overall) saves a hundred bucks or so. Time is made up and lost on the ground- not the air on most of our flights. Saving 500lbs of gas and taking 2 minutes longer normally would have you (cost wise) in the black, all efforts are destroyed when you wait 15+ minutes to be parked. I see the hourly cost argument but I also see that climbing to altitude faster (time wise) and decending at a higher angle (4.0degrees mentioned) and faster (while still at a lower power setting) kinda evens out on the time, yet the fuel savings is still there- at least in my rationale. This is the sole reason I brought up this topic, keep the replies coming...
You've got the right idea about how to do things in the CRJ. The only caveat is that you should always try to climb at a faster speed for the first 20,000 ft or so when leaving a hub or other busy airport. The mainline planes departing behind you don't want to get held up. After 20,000 ft or so, most of them have climbed well above you anyway, so it's not that much of an issue. Until then, you should climb at least at 290. I tried to do at least 300. Aside from those instances, I used a graduated scale depending on how heavy we were.
53,000 lbs - 250/.70
47,000 lbs - 270/.72
42,000 lbs - 290/.74
<42,000 lbs - 310/.76
Works pretty well, and you can usually maintain at least 800 fpm all the way up unless it's really blasted hot out. You're also right about going higher most of the time. WorldFlight calculates the next couple of altitudes automatically, so you've already got the burn numbers to be legal, so go on up. Saves at least a couple hundred pounds usually, and sometimes you can find more favorable winds.
decent at 320/.74 (to get an idle decent not a .77 acceleration) and the default planning to 4.0 degrees. I would be interested in seeing how it works out for others.
This is where I disagree. Most fuel efficient in the descent is a flight idle descent at .74/300. Going faster is actually decreasing your fuel savings because you're descending at a much faster rate. Doing the 300 knot profile gives you about 3,000 fpm descent at idle. Works very well. Pinnacle was talking about making this SOP, but they never got around to it.
The MX argument you give is not totally correct. Flying 5 more minutes will not equate to $80 in higher cost for the flight ($16 x 5) even though mx costs are what you say they are.
The majority of the MX costs are fixed costs, C-Checks, engine changes, line mechanics etc. These costs will be present whether the aircraft flies 10hrs/day or 8hrs/day. The actual wear and tear of 5 minutes of flying is rather insignificant.
Here's an example...I have a Learjet...I do $180,000 worth of MX on it per year or $500/day. This includes it's annual, and all required checks and having MX available 6hrs/day. I fly the plane 1hr per day....So Mx costs are $500/hr. If I now decide to fly the plane 2 hrs per day, my mx cost per hr flown would drop ($250/hr). Sure I would have more mx on the aircraft throughout the year, but overall the cost of mx would be distributed over more hours flown lowering the cost of mx per hour.
So....getting back to your example...Flying 5 more minutes will not directly cost $80 in increased maintenance.
Agreed. Most power-by-hour programs come nowhere close to costing more than the saved fuel. The best way to reduce mx costs is by de-rated/flex takeoffs. That's where the big savings comes in.
