Bad castings from the foundry (for all engines).
Fatigue over time, as the case thermal cycles, will create stress on any flaws in the casting. This stress will gradually grow into a crack. That crack will grow slowly until it can't carry the load anymore and fails.
Nothing you do from the pilot seat has any effect on all of this. The case is under a realitvely constant load, and heats up and down VERY slowly.
I appreciate that, thanks.
I was curious as there has been a rash of cracked cases around here, and preferably (as I am still not so familiar with the big lycomings - I'm a continental man myself) would be interested in knowing if there was anything I was doing that could cause it. I haven't been flying that particular airplane lately, but it'd be good to know if more experienced user out there had some insight.
My usual sequences for flight:
Break ground, and positive rate --> Prop back to about 2550 (Lycoming recommends this in their operational tips booklet).
1000' AGL --> Pump off, Power to 25x25 (per the company on the power setting) unless its really warm then I might leave the power up there for much of the climb.
Cruise --> 75% power (usually around 24 squared), 18gph (per company)
Descend --> Power at about 75% all the way down till I have to slow down.
In Range --> Pump on, and then about 1 to 2" MP per NM until I'm slowed down, and try to keep 15" or so until final at least.
Flare --> Power to idle.
This is how I operate, and is somewhat similar to how I operated the IO520F. Just curious as to whether or not I was cracking cases.
