You can have what ever opinion that you want, but the manufacturer agrees with me, it's straight out of the FCOM.
Unfortunately, bad habits get into the mix for a lot of airline training departments, that start doing things based often on what works in the simulator, and nobody bothers talking to the flight test pilots or aerodynamicists that designed the darn airplane!
A very good case in point is the use of rudder to recover from unusual attitudes, which was taught by several major airlines (AA and UA, among others) and may still be taught by one of the regionals. I know the director of training at the particular regional refused to back off of that, despite being told directly it was not wise by representatives of all the transport manufacturers (including the one that made the little jet they operated), all of the flight test people, the FAA certification branch, etc. This was at a working group that was part of a White House Commission, which I was involved in at the time, where the focus of our group was specifically transport category loss of control accident reduction.
Again, Boeing directly recommends initiating cross controlling starting at 300' on any hand flown approach that requires it for crosswind correction. The autopilot does it a 150'. As for the precision approach, true, I wouldn't cross it up while IMC, but the manual also recommends keeping it coupled if the mins are that low. Can you wait longer? Sure, it works most of the time, but if you have a really strong crosswind it is adding a destabilizing factor late in the game. Personally, it also depends on the amount of crosswind. If it's just 5-10 kts, it is hardly noticeable, but if it's 25 kts it requires more aggressive action. I think the other factor for 300' for the airplane I fly is that it is close to that point where ground effect starts to become noticeable. Starting a slow transition to a sideslip at that point gets you fully stabilized in the side slip at about 100-150', due the our high approach speeds.
flyover said:
Got to disagree with Seagull. 300 feet is too high to start cross controlling a transport jet. Start of the flare, about 50', is standard. You can slip the whole approach, if you want to, on a visual. I seldom saw that and it seemed like bad form to me, but it can be done.
But on any precision approach, to minimums, cross contolling at 300' wouldn't be done and certainly wouldn't be comfortable. So fly it the way you would if you were just getting the lights at 100'.
