Xcaliber
El Chupacabra
A little while ago, I was flying a 172 out of a class D airport, taking off from rwy 31. I had advised ground that I was going out for a northern departure. Now, I'm used to flying IFR most of the time, in which case, I can generally takeoff and turn on course, unless given other instructions. So taking off VFR, I got to a safe altitude, and proceeded with a right turn to the north. After I did that, tower came on and gave me a lashing about how standard departures from a traffic pattern are either straight out or a 45 turn to the side of the pattern, and that I needed a clearance to turn the other way. I was surprised by this, not because I didn't know what a "standard" departure is, but because I have never heard of needing a clearance before turning when VFR and have never had any problems from controllers by turning on course after takeoff.
The more I thought about it, the less sense it makes. On one hand, most times when you tell a tower which way you're going to depart, they say "north departure approved" or something like that. In this case, he didn't. I'm giving him the benefit of the doubt for that. But then I thought about the regs for entering class D, and all you need for that is to establish two way communications. If you get that, you can come in and do whatever the hell you want, except land, until ATC tells you otherwise (I'm not saying that it's a bright idea to just randomly fly everywhere, but you can). So if I'm VFR, have established two way comms, and tower hasn't given me any restrictions on my departure, can I not start a turn in any direction? I'm a CFI, so I feel like i should know this and it's really been bugging me. I should also add that there was no traffic conflict, as, by taking off, I brought the total number of aircraft within 20 miles of the airport to 2.
On another lighthearted note, is "squawk ident" real phraseology? I've heard it in two different movies (Transformers and Pushing Tin, if you're curious), both of which I chalked up to Hollywood just wanting to be cool by using the word "squawk" in a sentance
. But I just saw Mr. Dough write it in another thread, and that got me curious. I couldn't find it in the pilot/controller glossary, so am I right, or am I the ignorant one?
